Fork oil
Can I remove some fork oil myself? I think the guy where I got my fork seal changed put too much oil in cause the compression adjuster was backed all the way out and they seem real stiff.Kayaba forks
you can, but its not the proper way you should do it.
drain the oil, post what bike/year you have and fill in what these guys here recommends you
if you simple remove some oil (if this is actually your problem), you have no clue how much you should fill in at the next oil change.
this is in case you have a closed cartridge fork. on open chamber forks you can measure the oil level
Edited by kawamaha
