XR 200 Crank
No, in 94 Honda changed the fit of the right main bearing from press fit on crank and slip fit into the case, to slip on crank and press into case beginning with engine number 5705049, but all pre 94 XR185/200 two valve cranks interchange. Some the cranks from other 200s also fit. The change also affected the right case.
