Fork seals
how long should they last? I had them done on feb 12th and after todays race over 40 Beg. they were leaking oil.What should i do? make the place redo them? 2006 crf450
Its abnormal for fork seals to leak that soon.. but its very possible you have a tiny piece of dirt stuck in the dirt seal put your bike on a lift try pulling the seal down with a screwdriver ( keep in mind no oil should come out ) and run a tear off in between the seal and fork to remove any dirt. :banana:
if that doesn't work, then your seal is bad.
