DRZ Repair Question - Hole in Engine Case
I have an '02 DRZ 400 all stock except for the DOT knobbies, corbin saddle, and oversized rear sprocket. Riding it in a rocky offroad area I lost control and wrecked. I ended up smashing the bike into a cobble the size of a soccer ball. It punctured the case just above the frame below the drive sprocket. The hole is the size of 2-3 grains of rice stacked lenghtwise. I haven't been able to find a half of a case for sale anywhere, and I can't afford a whole new motor for the bike. I have used a couple different patch materials, but they don't seem to hold up long. PLEASE HELP. Spring is here and I want to be riding! Any suggestion as to the best course of action for this situation??
I don't think you can replace just one half of the case. If it is just a small hole punched in it would something like this work?
If it is not very big & not caves in hitting something inside I would think that a good two part epoxy to stop it up. Yuo need to clean it cleaner than clean to get rid of any oily residue, sand it slightly so it will stick, then apply the epoxy. Should work.
A friend of mine punctured his engine case(2002 DRZ). He used JB weld on it a few years ago. No problems since. Take your time and do it right...then get a case cover. That will cover the blemish and JB weld. Unless, I have misunderstood the location of the puncture. Good luck.
Clean VERY well and use JB weld. I had a patch on a bike in a very similar place, for years with zero problems, have since sold and it's still clicking right along.
Like everyone else said... JB weld is the stuff to use for a small hole like that... should hold up forever.
Hey buddy look for a two part product called Belzona. It is a really amazing product that earned respect on my boat. I am in the Coast Guard and we used it as an emergency patch on some holes up to 1/4" or so on our Fuel tanks. It held up until we went into dry dock for at least 6 months. it never leaked! The trick for any of these fixes is to clean very well and rough up the surface. Cast aluminum is very porous so it should adhere well then just before applying clean again with denatured alcohol.
good luck
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
