Front End Wash
Given that the front springs are proper for the rider. A fast over 30 expert.
What would be some of your choices for valving fixes for front end washing coming out of a rutted corner, top rev third gear.
Would you rather add in the slow speed shims or take out some re-bound?
The bike is a 2005 yz250f.
Just looking for different schools of thought I guess.
That can be fixed without revalving. Check rear sag first. If ok then either raise the forks a cpl. mm's or adjust frt. clickers. Try softer comp and/or slower reb.
doc
given sag is set, forks raised 5mm and clickers were played with....
Now onto valving, which would be beneficial.
I'm assuming adding a couple to the low speed.
