primary drive gear concern
I have the clutch cover off my 2008 530 about to do the crank seal when i noticed a small amout of wear in the case by the primary gear.I read on an old post here that there was a fault with the gear separating and destroying the case.I did check parts and found the part number to be updated so i would guess i'm on the right track or should i look for something else.I have ordered a new gear and nut and i guess iam thankfull i found this concern now rather than later.
