TTR50E Starting Problem
Hello from Down Under!
I have a problem with my sons TTR50E.
Whilst riding recently he put in down. After that it was blowing some smoke and running rough so I pulled it up and found that the airbox had filled with oil.
I removed the airbox and cleaned it up and since it was due a service also cleaned the filter and drained the oil and replaced.
Now it wont start! When I turn on the key and the kill switch all I get is a clicking noise which I believe is coming from the starter solenoid located behind the battery on the frame. Pulled the carby off and gave it a clean and cleaned the petcock. Still nothing.
I am not even getting a spark from the plug? Put on the spare plug that we carry..still nothing??
I had this problem recently on my WR450F and found it was a dead battery. Replaced the battery and it started straight away! So I bought a new battery for the 50 and still clicking and no spark?
Have visually checked the wiring and also the fuse on the battery and all seems OK.
Can anyone help? I am loath to take it to the dealer and get charge $70 per hour for something simple!!
Thanks.
