pw80 oils?
I just picked up a pw80. Can I use a regular 10/40w oil in the crankcase? Any 2t premix oils you suggest, (castor based?) or it doesn't really matter? Thanks for any replys.
yes, you can use that oil. doeent matter what premix oil. Everyone has their own prefference, i am dieing to tell you what to use over the other but just use any 2t pre mix on the shelf at a dealer. once you use that oil, i guess that what you will think is best and think its better than others,hell, i think castors are better than synthetics for example :banana:
You probably want to stick with oil injector oils to be safe, however, I'm pretty sure the PW80 will run with 20W50 in the oil tank, I wouldn't necessarily recommend it.
Transmission, 10W40 4 stroke, ATF (M/D III), 10W30 should only be used if it is not marked "energy conserving" in fact, always check non-motorcycle specific for this label, reject if it has it in the seal on the back of the bottle.
