new engine breakin
non synthetic oil, first start up- let idle till hot then let cool down and retorque/check valve clearances, then take it to a track- ride the first lap kind of slow checking for unusual noises but at the same time not staying at the same rpm (shift alot) then do about 2 or 3 really hard laps with alot of shifting and engine braking.. go home and let it cool- change oil, retorque, ect.. after about 1-2 hrs you can go to the oil you want and ride the bike normal, if you did just a top end after about 15-30 minutes of riding everything is broken in
Start it up and ride it hard, with lots of decel to set the rings............ You wont need to retourqe anything they dont loosen up that fast or at all usually.........IMO
