acct/mcct
Hey guys. Pulled my acct and am curious what you guys think of the stick out. I think its out pretty far. I matched my mcct stick out and saw a few pics on here showing more threads exposed on the lock nut side then mine. I just want to confirm my cam chain with those more experienced with this. I want to ride it so bad especially since I'm off for 2 days and the weather is nice. But if the chain is, well from the pic of the tensioner is stretched or not advised I wont. I'm placing an order through tt next week and rather get it all at once.
While I'm at it can someone give me a link to a downloadable manual. I intend to change the cam chain and do all the locktite fixes.
I am not certain but I would think that since ACCT is spring loaded, it would protrude further uninstalled than it does installed. Install your MCCT and tighten it until the sound just goes away and call it good.
The acct does fully extend once removed. On mine I was able to see where it had been by the wear on the ratchet teeth. I dont think you should use the acct to guage the mcct install. Just go by your mcct installation instructions.
If I were you I wouldn't risk just fitting an MCCT without knowing the condition of your cam chain.
If it has stretched (which is highly likely if you've racked up some miles with the ACCT) and it fails your wallet will cry.
Get a caliper and measure the chain for stretch, or get someone else to do it.
Then if neccessary install a new chain, MCCT, and whilst you are at it do all the loctite fixes.
Cheers,
Con
what year is your bike, that's a good determination of how long the acct has been in there to know if the chain could be stretched. If it's a newer bike then you should be all set. Like gtlegacy said, don't use that as a guide for the mcct. install the mcct by sound
ah ok guys. its a 2000. 6000 miles. I thought I heard a like ticking but it is constant and does not change sound at different rpm. I began to think it was something shaking because it is not always making noise.
What sort of mileage would dictate a new cam chain? I have just over 2k on my 2008 and I want to change to a MCCT soon, should I play it safe and get the new chain or just install the MCCT?
is it normal that it doesnt push back in? looks like teeth are inside of it unless its a spring. There was also blue locktite on the 2 allen screws that mount it.
Can someone provide a measurement for the cam links? My local stores dont have a manual so I'm going to order it next week through tt along with a few other things including the cam chain.
well I figured out how the acct works. removed the small bolt at the end and rotated the screw. It works very well. Just got my mcct installed and I'm putting it back together now.
thanks for the help guys. I wish I never made this thread but am glad to have at least asked the stupid question without stupid mistake.
  • Similar Content
    • By Bignerd0100100
      Hey all,
      I'm looking at buying a 2004 Suzuki DRZ400EK or at least I think it's an EK according to Vin lookup websites, but it does not appear to have a kickstarter. I was told the bike was owned by a motorcycle dealer and that it has a current green sticker, and a California license plate but has not been registered for the streets since 2011. I want this as a dual sport but am not clear if the fact that it already has a plate means I am good to register it or if maybe they took away the ability to register it after it was plated, California loves to do that kind of stuff. Since the bike was owned by a dealer I would think they were up on the latest regulations in California, but who knows. Can anyone add any insight as to what I should look for on the bike itself like the carburetor, model numbers etc? Or do I just try my luck at the DMV?
    • By smokey9lives
      Hi,
      I have a 2003 DRZ (actually a KLX400) and the head tube bearings are shot.  I ordered a new set to install but I'm wondering if anyone has any recommendations on other parts I should replace while I have the front disassembled.  I was thinking about new rubber fork protectors, but are there other things that wear out on the DRZ front ends that you can only get to when disassambled?
      I also broke off a replacement key that I got for the steering lock.  I must have been made of cheap pot-metal.  Should I just remove the whole lock mechanism?
      Any tips or tricks for getting the old bearings out and the new ones in would be welcome!
      Thanks!
    • By antonyp
      Hey Guys,
      I recently bought a 2003 DRZ400S and thought it would be a good idea to check the valves clearance etc . I timed the engine on TDC with the magneto mark aligned as per the manual but I find the cam timing slightly odd. The arrows pointing upward are on the 1st and 15th pin as they should but with the magneto timing mark aligned they are not perfectly straight. Same goes for the arrows that should be parallel to the cylinder head casing. Is this normal or should they be absolutely perfect ?
