stroked crank?
what does it all require?
do I just buy a stroked crank and a rod and install it? im not going to have to mess with any timing or clearances like piston/valve clearance?
when/if my crank ever decided to go (only thing on my bike I havnt replaced yet... sure hope its not this summer!!) I am probably going to throw a stroked hotrod crank+rod into it, unless someone here has a better suggestion.
You MAY need a piston that has been machined to accomodate the longer stroke...I ran into this when building a 342 stroker motor for my Mustang. Not completely sure about a bike though, looks like all the kits out there just include the crank and rod so they may have taken the extra length out of the rod. I would definetly go with a good aftermarket piston and talk to an engine builder or company that specializes in this type of mod...Ron Hamp, Big Bore Thumpers etc.
Stay stock on your crank. JMO. It causes more engine vibration than you will like. Your best bang for the buck on power is to get head work. If you wanted to up it just a little bit more, you could slap a high comp piston in it at the same time. Of course that all needs a good exhaust system to be worth anything. :banana:
+1....but my buddies YZF450 quad, which has been bored, stroked, cam-ed, etc is one BAD machine in the dunes.
well I figured when the crank does go, which I imagine is the next thing to go.. why slap a normal one in there when I can put a stroked one instead? engine vibration isint a concern for me, and I dont race so the "too much power" theory does exist with me :banana:
I would also probably throw a big bore/high comp piston on it also. mine is already stage 2 cam, exhaust, JD jet kit, stock piston. SS valves with the 08 head + exhaust valves which are smaller than the 05 which takes away from my top even more combined with the SS intakes valves which is fine.
I have a friend who has a yz450f bike thats bored 2mm and stroked 3mm, I believe its something like 510+ cc now. I havnt ridden it but imagine its pretty bad ass, he doesnt seem to have any problems with the extra power where we ride at. only complaint is the tires he goes through.. basically I just want a ridiculously powerful bike, unless it takes away from my reliability, then its not worth it. ive ridden my 450 for quite a while now and have gotten way used to the power, its lots, its plenty, but I always want more and more and more.. basically a 60 or 65 HP 450 and ill be happy for a few summers until I want more!
will a stroked/bored engine last significantly less than a normal engine? if I have to rebuild it every 50-100 hours forget about it! the stock engines last 200+ hours IMO.
just want to make sure im prepared and have my $hit together for when the time does come that the crank needs to be replaced, which is hopefully not soon!
I was hoping for 200+ hours! My 100% stock motor's crank went at 98.0 hours. I think it's kind of a crap shoot, but those mods certainly wouldn't make it last longer.
ouch. I seen your pictures. my bike has gotten louder lately, but I keep telling myself its just the SS valves that I installed and not the crank :banana:
mine currently has 120 hours put on it by me, and the first owner put on 10-30 id imagine. I just sure hope she doesnt decide to go this summer... I will be very mad if it does!
My friend who is similar speed to me bought an '07 in '07 (I bought mine in '09). Never touched the motor, just did valves and piston this winter at an estimated 130 hours; although I'd estimate closer to 300 since he rides the same as me times 3 years.
yeah it seems like some people get awesome bikes, and others get bikes that were either made on a monday or on a friday! :banana:
  • Similar Content
    • By 33KTM350
      I just bought a Magura hydraulic clutch for my 2014 CRF450R.  Bought it thinking install would be easy, and I'm not sure that's the case now that I have the product in my hands.  I have searched the forums, YouTube, etc for install help specifically for my model year (2013 and 2014 are same really), and haven't found anything specific for the 2013-2014 model install at all.  Instructions from Magura are TERRIBLE, and are not specific at all to the Honda - generic instructions - so I'm debating if I want to return the product, cuz I don't want trouble or a big install job.  Question: for the 2013-2014 CRF450R install ONLY of a Magura Hymec hydraulic clutch - other model years are different and thus it won't be helpful for other model years - do you have any tips or feedback?  My concerns are below...
      1.  The 2014 model has a sleeve behind the clutch actuation arm that the Magura clutch slave cylinder fits into.  Stock, the sleeve holds one end of the cable, with a nut on the other end to keep the cable end tight in the sleeve.  The Magura slave cylinder, however, slides into the mounting sleeve  - but does NOT have a nut: the tension from the clutch actuation arm pulling on the metal Magura slave cyl tip end is apparently supposed to keep the Magura slave cylinder tight in the mounting sleeve.  Q: Will the Magura slave fit in to the mounting sleeve easily, stay tight, and is there any adjustment needed in order to keep the 4-6mm of freeplay that Magura recommends?  How easy is it to get the Magura slave fitted into the sleeve and the metal tip in place?  Is there enough freeplay between slave and tip end to mount in actuating arm AND the holding sleeve, so that the holding sleeve doesn't need to be unbolted?
      2. The stock clutch cable and OEM setup runs out of the mounting sleeve (see pics marked "metal starts", and then runs through a metal sleeve that routes the cable through the engine compartment - keeping the cable away from the hot parts of the engine case, so as not to melt the cable insulation (I believe).  That metal sleeve is about 6-8 inches in length.  The Magura clutch cable, on the other hand, exits the Magura slave cylinder at an angle - yet has no such metal routing.  I don't think the OEM metal routing sleeve will accept the Magura cable either, so a) the OEM metal routing sleeve would have to be removed first before installing the Magura - and then b) you have to hope that the Magura cable can be routed in such a way with zip ties holding the hydraulic line that line will not touch or be close to the hot metal engine casing as you route it through the engine.  Q: how easy was it to get the OEM clutch cable and metal routing sleeve out?  Easy as unscrewing the nut on the other end of the OEM cable, on the other side of the black rubber cable flange in my pics?
      3.  My stock clutch pull isn't bad.  I just like the feel of a hydro clutch.  Any feedback on how much better feeling and easier pull will be with the Magura?  What's your feedback on the difference?  FYI, I'm leaving my clutch plates and springs stock.
    • By Eric Blasiman
      We have a 2016 CRF450R with about 11 hours out. never ridden hard always check the oil and change when needed along with the air filter. Took care of the recall that was required as well. Well when riding the bike was stalled out. Went to try and kick start the bike again. the kick start lever just back up jamming my knee into the handle bars and some how ended up cracking the case right by where the kick start goes through the case. Has any one had this happen or heard of this happening? What is the cause?
    • By crfjunky1320
      Any advice on what should be replaced while I have the top end off for a valve replacement. Will do headgasket and springs of course, anything other parts you would recommend while I'm going at it?
      Thanks!
    • By Ron Whitfeld
      The dirtbike is on it's forth year right now on the same motor job. I have to jump start it. Is it worth me trading for a 2009 650 brute force with7000 miles? Need some expert advice. Thanks
    • By Lucas Hansen
      Just wondering what you guys do to remove black marks on your seat. My 08 crf450r has the red/black seat, and after each ride there are some black marks on the red from my riding pants. Not scuff marks, more like patches of black residue from my pants rubbing on the seat. I’ve tried the magic eraser which seemed to do the trick, but lately they seem like they aren’t coming off. Also tried scrubbing bubbles with a brush and no luck. Not too worried cuz I have an spare OEM seat, but I’d like to keep this one nice. Any ideas? Maybe I shouldn’t wear black pants?
