Stuttering!!
Ok when im on the gas it pulls fine..whenever i let of there is no decel pop or nothing but when im just cruising it has a little stutter or pop is this carb. related?
and when i do that? if it goes away im guessing the TPS is bad? thanx for the reply by the way
having similar problem before and after rejetting through the whole throttle. if it works fine with the tps unplugged do i leave it off??? im assuming no, i need to work on timing right? ack...
