Won't Start Cold
I have a 2005 CRF250X.
I have a hard time starting my bike cold.
With choke on, not with starter, not kicking. I have to push start it.
Once I have run it 10 minutes I can get it to start kicking it,
but not using starter (well sometimes, usually not).
Put a new plug in it that helped. Can barely see the spark.
Bad coil? Saw a few on ebay are the years interchangeable?
Is there someplace to by this new other than Honda dealership?
Thank you!
Try turning up the idle. Or.... sometimes I have to twist the throttle two or three times before I hit the button when it's cold. This gives her a little shot of gas from the accelerator pump. It usualy fires right up after that.
You may want to start by checking your valve adjustment.
Not starting cold is one of the first signs of the intake valves being too tight.
Have you done the CCC mods and rejetted the bike or is it stock? Before you check the valves, I would answer that question first.
Cold. Turn the fuel on, choke on, lean the bike over past 45deg for the count of 4 (fuel should dribble on your foot). 3 quick twists of the throttle and hit the button. should start right up. If it starts then dies give it a couple more twists on the throttle and try again.
If you have not checked your valves i would do so. It takes about 30-45 min to do and costs nothing but your time.
FYI:
Turns out it was one of the intake valves.
WAY OUT OF ADJUSTMENT!
Replaced the shim, starts and runs easy. :thumbsup:
  • Similar Content
    • By Hayden Ploeger
      So I have never actually posted on one if these forums. I usually just stalk them to get answers but I messed up and I might be out 800 bucks🙃
      I have a 2013 CRF250L that I recently bought and I wanted to get supermoto wheels for it. I got online and almost ordered a set of warp 9 wheels but then I saw an add on Craigslist. Long story short I purchased lightly used warp9 wheels from a 2012 CRF250X not realizing the axles are different sizes. The rims are the same size as what comes in the kit from warp 9 but the spacers and bearings are larger on the wheels that I got. Does anyone know if I can buy new bearing and spacer kits to go in these hubs to fit them on my bike or will I need to purchase new hubs entirely?
      I work on a fishing boat and I'm off the coast of Oregon for a few weeks and wanted to order something so I can get these wheels on my bike when I get home.
      Thanks,
      The guy who f***** up
    • By yrun
      I have a new 16 crf250x.  Would like gear it up a bit for two track, orv trails.  How much can i drop the rear sprocket size without shortening the chain.
      Thanks men!
      Joe
    • By yrun
      I was working on installing new needle for JD jet kit today. While trying to get a bit more rotation on the carb i broke a little plastic tee on the top of carb (left side). I think its some sort of vent? Not sure if the brass part is threaded into carb or not? At any rate it will have to be replaced. Wonder where i'd get this little item?
      Any ideas?
      Thanks joe
    • By ronbuell
      Ever been bored or really ticked off by not being able to reach your fuel screw for trailside adjustments?  Well, I decided to do something about it, and not spend a bunch of money to boot!
      Parts liste included:
      Short length of brass tube. Short piece of old, broken speedometer inner cable. Nut from the rejects bin.   I welded the nut to the speedometer cable inner and soldered the other end to the fuel screw using the brass tube as a connector.  I didn't need or fab up a holder for the end, but I wouldn't be too hard. My DIY flexible fuel mixture screw works great and the price is right! I highly recommend this mod.
      Cheap, but effective DIY fuel mixture screw
    • By Frana
      Hi everyone. I’m new here so I don’t really know what to do but let me explain what’s up, so I bought this 2008 CRF250X today and everything looked in tip top shape, but within a few minutes of riding the engine and radiator gets to hot to touch and then the bike dies at low RPM, then it is a hassle to get it started(i drained the battery trying) and once it fires it dies super easily again like by touching the trottle or just idling and I have to be super cautious on the throttle to grt it going. I don’t know if it is overheating or if there is another problem, if anyone could help me it would be very much appreciated.
