Air temp sensor help....
Well I was taking my subframe off last night, so I could ship my shock to Factory Connection... long story short, I didn't see the wire running to the Air temp sensor tucked up right under the top of the subframe rail, and I pulled the wires out of the connector. Could someone tell if the green wire is on the side you press to release the connector, or the opposite side? I would greatly appreciate any help. Thanks
Shawn
Could someone pull their seat, and pull that plug off the sensor on top of the airbox boot and check which side the green wire goes in? It sould be the clip side, but I would like if someone could confirm it.
