yz490 fork oil
5 or 10 wt fork oil. 5 to 6 inches from the top of the fork tube with the forks fullly collapsed and fork springs removed. Lots of times you need to experiment to gte it set up for you.
Can anyone tell me the weight and amount of fork for a 1982 yz490?
here are some stats and what I use
Front Forks: 43mm
Spring length=555mm
Spring width =36mm
Spacer length=80mm
Oil weight =15 WT
Volume=620mls
