dan4th83 Posted March 18, 2010 Ok so i put a yz426 engine into a rebel 250 frame. I put in a wr450 stator and did the pink wire mod (not sure on the color). So i rode it around just fine for a couple months with no battery and now my fans for my radiator and my headlight burnt out. So i figured maybe it got messed up because of the wrong voltage. By the way the stator wire is ran through the rebel regtifier thing to give my dc power. So since i blew up the lights and fan I decided to add a small 12 volt dc scooter battery. So I hooked up the + on the lights to the batt but the new lights did not work till i disconnected the grounds from the frame and hooked them up to the negetive on the battery. So now the way i have it ran is negatves to batt and positive from the rectifier is a T to the lights and one to the batt. So now the lights work but if i disconnect the batt positive the lights wont work with the bike running. So i think maybe i have to take one of the grounds off the frame and hook it to the battery negative so that the lights will work if the batt is dead but i dont know what one. Oh and by the way, does anyone know where to get a fan for my radiator? I used to small computer server fans but i figure there must be one meant for a bike somewhere. Share this post Link to post Share on other sites
RideAgainstTheMachine Posted March 18, 2010 Have you tried running a ground from the battery to the frame? I absolutely love that bike, any videos of it running? Share this post Link to post Share on other sites
dan4th83 Posted March 18, 2010 i thought about that, but frm what i am reading on here. it is not good to mount the ac ground and dc ground both to the frame. I think i just need to figure out what wire is the ground wire to the lighting coil and hook that to the battery so that way the entire lighting system is on a floating ground. I will try to get a video for you once i get the light thing figured out. Share this post Link to post Share on other sites
nick4634 Posted March 18, 2010 Hey I have a rebel 250 also and that looks like a cool project. How hard was it to mod the frame and exaust and where did you mount the rads Share this post Link to post Share on other sites
ktm868 Posted March 18, 2010 ktm hard parts fan will work! that bick is amazing!!! keep us posted Share this post Link to post Share on other sites
dan4th83 Posted March 19, 2010 I did not mod the frame. I built a bracket to hold the radiator. and i used the stock header and conected bendy tube with a car mufler tip Share this post Link to post Share on other sites
dan4th83 Posted March 19, 2010 ok does anyone know how to tell if power is ac or dc. cause when i hook a volt meter to a car batt it says 24ac in ac setting. Cause when i measure the power from the lighting coil at idle i dont know if i am gettng 12ac or 6volt dc. Share this post Link to post Share on other sites
RideAgainstTheMachine Posted March 19, 2010 what ac is grounded to the frame? how come you are using the rebel rectifier wouldn't be easier to just mimic the whole wr system? Share this post Link to post Share on other sites
02WR426Cali Posted March 19, 2010 Very cool project you got there! Can't wait to see it in action. Share this post Link to post Share on other sites
dan4th83 Posted March 19, 2010 I only have a wr stator. It is a yz motor, that is why i am using some rebel parts. Share this post Link to post Share on other sites
02WR426Cali Posted March 19, 2010 I think a WR426 stator will solve your problems. The 450s have a battery making them DC I believe Share this post Link to post Share on other sites
RideAgainstTheMachine Posted March 20, 2010 any luck yet? I would try grounding the battery to the frame if your lights at fans are dc which they should be if their going through a rectifier I't shouldnt cause any problems. Share this post Link to post Share on other sites
mutt2jeff Posted March 20, 2010 I bet that little things scoots, very cool. Share this post Link to post Share on other sites
dan4th83 Posted March 20, 2010 I do have a wr426 stator, not sure why i said 450. But i just have to get the light stator ground off the frame and to the battery. So i will be trying to figure out where the stator ground is today. Share this post Link to post Share on other sites
dan4th83 Posted March 20, 2010 ok so here is the deal. I remember doing the pink wire mod to get the lights to work without the battery. But now I want a battery and best i Can tell is that the pink wire is the ground wire for the lighting coil. So right now the pink wire coming out of the stator is cut and the pink wire that runs to where ever, cdi i guess is grounded to the frame. So i am thinking that maybe the pink wire that is cut maybe should go to the ground on my battery for the battery to charge. Does anyone know if that is right? Share this post Link to post Share on other sites
paolo h Posted March 20, 2010 look for a drz400s fan on ebay. Share this post Link to post Share on other sites
02WR426Cali Posted March 20, 2010 Ok you have a wr426 right? There is no battery for that motor. So are you using both the WR and Rebel wiring harness' together some how? Share this post Link to post Share on other sites
RideAgainstTheMachine Posted March 20, 2010 I dont know enough about them try posting the the yz450 or wr450 forum a lot of smart guys in there Share this post Link to post Share on other sites
dan4th83 Posted March 20, 2010 no i have a yz426 motor with a wr426 stator yz wire harrness and cdi box. oly that is a rebel is the frame bits. Share this post Link to post Share on other sites
