Fracture Posted March 18, 2010 (edited) Hi fellas, I'm having trouble locating a piston for a bike I shouldn't be fixing, a 1984 XT250. It's pretty much an XT350 with a smaller bore, and I think a different primary reduction ratio in the gearbox. Anyway, I'm not having any luck finding a piston. I need a 1mm oversize, and there are 2 part numbers that fit - XT250 - 30X-11638-01-00 SRX250 - 51Y-11638-00-00 Bikebandit can't get one, and I've been looking EVERYWHERE for one. I have everything else I need to fix her up, but this kind of puts a hold on things. I'm open to NOS OEM, Aftermarket, even custom. Does anyone know where I can locate one? I have the old .50mm over piston that a custom shop could copy, (minus the big hole in the middle hah). Can anyone shed some light? Edited March 20, 2010 by Fracture Share this post Link to post Share on other sites
Fracture Posted March 18, 2010 (edited) I have just found out that TTR250's have the same bore and stroke. I wonder if there is a chance that will fit? hmm more digging to do... edit. TTR250 piston does not fit. The compression heights differ by around a tenth of an inch. I'd have to take around .105" off the top of the jug to make the TTR piston fit. Can I do this without fubaring the cam chain tension? Edited March 19, 2010 by Fracture Share this post Link to post Share on other sites
