klx 110 max wieght
From what I've seen there is no limit. However, adults should add a cradle mount or at least longer peg mounting bolts if they are gonna jump it. A lot of adults have ripped the peg mounting bolts out of the engine.
is there any brand that i should get these longer peg mounting bolts from thanks 👍
Take a stock one out and bring to ACE Hardware to match the threads. I don't recall the length, so you will have to measure the depth of the mounting hole to determine how long of bolt you can use.
