Electrical on 93 200 question
As many of you have seen I have been working on this 93 KDX200 bike and the last thing I need to work out is the electrical. Putting a volt meeter to the wire outlets I get an eratic voltage bouncing around when the bike is idling. Is that normal? I can't get the lights to come on and not sure if it's the wiring or the lights. Didn't want to go buy lights if the ones I got are good, just maybe I have them hooked up wrong. Also I 'm not sure if the headlight switch is working right either. Any tips?
You got it set to DC right? It should be one level (maybe up/down slightly on rev), maybe your regulator is bad? I'm in no way an expert but I had a floating ground on my bike, PO had DS stuff on it, which was screwing everything up like the issues your having... Have you removed the stator and checked that?
Silly me! it was a non resister plug in it. PO must have put in not knowing. So a resister plug took care of it. Thanks
