Offset triple clamps for 2005-2007 kx250
RG3 might. Of course, you can get some custom made.
2004 - 2005 KX250F triple clamps are the same offset as the two stroke. 2006 and newer have the steering stops on the back of the clamp, not the front. The tube diameter, spacing, etc.may be different as well. They are 47mm Showa forks, not 48mm KYB forks.
RG3 has 21.5's.
2006+ KX250F Fork tube diameter is different. 450's may be the same, but would have the incorrect stops.
