DR 350 header pipe
I need to know if going from stock to a 1.5 inch header pipe with can will help i dont know what the pipe came off of originally but it was on a 02 426 is it worth making a new header pipe or should i use the stock 1 inch and neck down the can please let me know
Jessie at Kientech sells a larger diameter header for the DR350's. The bike does not need it unless you running a big bore setup or performance cam. Most 250 MX four stroke mufflers would be a closer fit to the smaller diameter DR header.
