Shock link bolt clearance
Mine had a pretty snug fit and was hitting in the same spot but I was able to wiggle it out eventually. If you need to, carefully notch or flatten the flanged part of the bolt with a grinder or dremel tool, line it up where it was hitting and slide it out.
Don't forget the safety glasses...you can walk on a wooden leg but you can't see through a glass eye. 👍
