wr gear swap
i know im beating a dead horse but i couldnt fing a clean answer, has anyone just taken the main axle and countershaft from a wr and placed them into there yz? can i be done? i found a wr with a melted head for CHEAP!! just wondering if it would work.. thanks
there is a mountain of info on the wr swap here.
The wr first gear will not fit without some case grinding.
you can do 3-4-5 as a drop in but for 1-2 it is a little more complicated.
There is a good post here with pics, part #'s and everything else you could need.
ya i know about the case having to be ground and i have seen a lot of really good info i was just wondering if i could put the whole wr assembly in my gear box... so instead of pulling gears off the shafts just put the wr shafts and gears in my yz geabox... thanks
You are aware that these gearsets are not WR250 gearsets, you did not mention that and as far as I personally know only the WR400 & WR426 work as having done that before. I have seen mentioned here that someone put in WR450 gears but I have not experienced that.
