Programer problems
Has anyone had problems using the Honda programer with Windows Vista? I keep getting the "unable to shift to data trans mode. I have tryed every way to make this work, it appears that Vista doesn't like the software drivers. ANY IDEAS?
you'll need to change the comm port in the device manager, however the only way you can change the comm port is with the device plugged into a USB port. other wise it is not in the orderd list in the Device manager. had me stumped for quite some time.
click start the window icon lower left of screen
right click on "computer"
upper left click on device manager
click "continue" on pop up window
about three-quarters down list, open "ports (com & LPT) this option will only appear if the HRC tuner is plugged into the USB port
double click "silcon labs"
select "port settings tab"
click on "advanced"
bottom left "comm port number" select "com1"
then "ok" out and your set.
