Remove standard airbox xr250RF twin carb
Comes out the left side and the right air duct will flex around the shock/spring. Might be easier to remove the shock, or at least unbolt the top mount, although I've done it with the shock inplace.
Three bolts hold it in, two on top and one on the right side. You will need to push it down and forward to fIt thru the triangular opening in the frame tubes. Pull the top aft corner thru the opening first. Difficult but doable.
