Clutch outer bolt ?
This is a 01 CR80 but I imagine all bikes are pretty much the same as far as this goes....
I installed a new clutch and I can not tighten the clutch outer bolt since the whole unit spins with it as I try tighten, I imagine only way is to take it to shop and they do with air impact, is that correct or is there another way I am missing ?
Just wedge a penny in between the gears, that's what I always do, or put the bike in gear and wedge a piece of wood between the spokes and swing arm.
Thanks! ...the wood method worked, do you know the approx torque it should be as I do not have a manual. I will check it then if some one knows.
