Carb Adjustment Question
Could someone post the adjustment specs for the carb on a 1994 Timberwolf 250(TFB250)?
Specifically the mixture adjustment screw and idle screw initial setting. The float would help too.
I don't have any documentation yet and the carb doesn't appear to have any numbers on it.
Sorry to be askin about something I would know if I had the docs.
For anyone searching the archive for the info:
Jet needle clip position 4th groove from the top, float height 21-22mm from gasket surface with gasket removed.
Pilot Screw out 1 -1/4 turns as a starting point.
