More crank seal help
Is your problem because when you try to loosen the bolt, the whole clutch basket turns? If so, use an Impact Wrench. You can easily hold the clutch by hand when you do this. I use a setting of 2 out of 4 on my air powered impact wrench.
It may have some loctite on it to. A tiny bit of heat will soften it, but be careful with open flames catching tranny oil on fire. And too much heat may cause crank or bearing problems. Of course as you are changing the seal, you dont' ahve to worry about it.
