CRF 250x starting problems
i have a 2005 crf 250x and am having trouble starting it when its cold. before i reshimmed it it would not start at all unless you bomb started it. i reshimmed the valves and now it starts but it takes about half an hour of kicking it before it starts. i have tried adjusting the mixture screw and it hasnt seemed to help much. when it runs it idles very high then it slows down and stalls. would it be somethin wrong with the carb? i would apriciate any responses. thanks
try your carb for sure, valves arnt gonna cause the problems you described^. check your float and jets. Then look at your choke different bike like to be started differently. lastly if this is a winter problem maybe your fuel is bad and/or fuel lines are bad.
