sx 125. only 1st gear works
I took my sx 125 out on the dunes for the first time... starting goin up a hill and went to shift out of first and there was nothing. it will only stay in first gear and there is no nuetral either. also the clutch wont even engage.. HELP me please!👍
there is a part in the right side case near the clutch that sometimes comes loose or a roller in that part can break. So, drain the oil and look for pieces on the drain magnet. Then lay the bike on its side and take the large right side case off. It is part of the shift mechanism to the left of the clutch. Check for loose or broken parts there.
Did you change anything since you last rode it? Did you move the shifter? Change sprockets?
