Leaking fuel
What would cause a fuel leak from the pump cover where it bolts to the bowl. When you twist the throttle fuel leaks from where the bolts are. There is a single O-ring. Is that all that should be there?? Working on it right now, if anybody is out there!! Thanks!
├Ś
├Ś
