nismofun Posted March 22, 2010 Hey everyone, After searching and trying to decide what bike to get with the intent of turning it into a motard, I ended up getting an 2002 DRZ 400 kicker and now I'm in the process of getting what I need to make it street legal. I've read tons of threads on here, looked at different kits, and just wanted to see if someone could find a hole in my plan. I plan on getting most of the parts from ebay, except for the ones where it costs more there, or they plain don't have them. Item DRZS Switch___________45 DRZS Harness__________45 Trailtechx2 headlight____81 Edge2 taillight__________62 NOT EBAY Generic LED Blinkers_____30 Generic Horn___________10 Bar End Mirrors_________30 Hydro Brk Switch Frnt___20 NOT EBAY Hydro Brk Switch Rear___20 NOT EBAY LED Flasher Relay________7 Vapor w/Dash_________165 NOT EBAY 12v Battery ub1213_____17 Total Cost____________532 Couple of questions, do I really need a battery to keep it all going? I don't like the idea of being without lights if the bike goes lame on me. Is there a cheaper price for the Hydraulic brake switches? Do I need both? I figure all the wiring will be there in the harness and switch to run everything and then just track it all down to where it goes, and get rid of the unneeded wire. That part probably costs a little more than making my own harness, but should be slightly cleaner/easier in my mind. So did I miss anything, or could it be improved on? Thanks for the wealth of info and I will be getting the MCCT and case savers in short order as well. Share this post Link to post Share on other sites
BONESTOCK Posted March 22, 2010 You will need a battery to keep it all going when the bike isnt running. I wouldnt add a battery though. Other than that seems pretty nice! Keep us updated. Share this post Link to post Share on other sites
panaman Posted March 22, 2010 I would checkout the Tusk Enduro Lighting Kit..... It has a ton of what you need in it already and is like $160 bucks you can get it at rocky mountain and its part number is Part# 1285760004 Share this post Link to post Share on other sites
tjamscad My Ride Posted March 22, 2010 dont for get that your headlight and brake light need to be DOT rated, you might want to check the voltage regultor i hear they cant support a battery. Share this post Link to post Share on other sites
nismofun Posted March 22, 2010 After thinking about this a bit, and talking with Forrest@Wheeling, I think I'm just going to get the DRC EZ electric kit from him. The differences in items are no battery and no mirrors included, but I don't have to mess with a harness either and have someone to go to for any issues instead of being SOL. Wiring will now be 246 from wheeling, computer and headlight 247 from motostrano, mirrors 30 so it'll total out at 523 after s/h plus 30 for mirrors. My only concern is how long will batteries last, and how bright will the lights be. The Tusk is tempting on price, but I don't know about the battery and quality. As for DOT concerns and passing inspections, I don't think they check that. At least they didn't check on my street bike when I had that inspected. Share this post Link to post Share on other sites
Noble Posted March 22, 2010 nism - Sounds OK. Myself I would not bother with the DRZ S wire harness. I think it will be more confusing than helpful. Also I would buy an aftermarket switch pod, in place of the Suzuki. It will have all the functions in 1 place. K & S about $60. Brake switches are about $20 each. Depends on your state if you ned both front and rear. No you do not really need a battery but it will work best if you have one. Required if your state says the lights need to burn with the motor off. How will you mount the battery? DRZ E battery box is an option. DRZ kicker regulator/rectifier will work fine with a battery. Post 3 OK - Recheck you parts list and prices. What about a tail light? Share this post Link to post Share on other sites
nismofun Posted March 22, 2010 (edited) nism - Sounds OK. Myself I would not bother with the DRZ S wire harness. I think it will be more confusing than helpful. Also I would buy an aftermarket switch pod, in place of the Suzuki. It will have all the functions in 1 place. K & S about $60. Brake switches are about $20 each. Depends on your state if you ned both front and rear. No you do not really need a battery but it will work best if you have one. Required if your state says the lights need to burn with the motor off. How will you mount the battery? DRZ E battery box is an option. DRZ kicker regulator/rectifier will work fine with a battery. Post 3 OK - Recheck you parts list and prices. What about a tail light? Just got off the phone with Forrest. Got the DRZ EZ kit w/ Edge 2. Now I'm trying to decide if the dashboard kit for the vapor is worth the extra $50 for 4 lights. I'm fond of the neutral indicator, and temp warning--but how "useful" is it really? And finished ordering the rest from the TT store. Thank you new member discount. got the headlight, computer, case savers, and MCCT on the way. Here's hoping for a delivery by this weekend. Edited March 23, 2010 by nismofun Share this post Link to post Share on other sites
tjamscad My Ride Posted March 23, 2010 DOT tires?, I think that is a must every where Share this post Link to post Share on other sites
tjamscad My Ride Posted March 23, 2010 In OK the process is pretty well mapped out by a member https://thumpertalk.com/forum/archive/index.php/t-679273.html Share this post Link to post Share on other sites
nismofun Posted March 23, 2010 Tires are next, but I can't decide if I want to go street oriented on the 21/18 or more of an offroad tread. Right now It'll mostly be commuting on paved roads with weekend farm riding (dirt, grass, woods), but the ultimate plan is to have a set of off road tires on the 21/18 and a set of 17s for the street. Looking at the kenda 270 or similar. Doing the research on that now. Missouri isn't too hard from everything I've read to get it plated, and some of the stuff I'm getting I don't actually need, but want for personal/safety reasons. Thanks for the comments. Share this post Link to post Share on other sites
tjamscad My Ride Posted March 23, 2010 Tires The stock DRZ400S tires are a death trap in the dirt. They should be the first thing you replace if you are going to go in the dirt. Since the DRZ400S is a dual sport bike we will need to find some Department of Transportation (DOT) approved knobbies. Dunlop 606's are very highly rated Pirelli MT21's are a good all around tire that will last for about 2000-3000 miles of pavement. Kenda K760 TrackMaster II in the rear, and a Pirelli MT18 in front, very aggressive DOT legal combination. Share this post Link to post Share on other sites
nismofun Posted March 24, 2010 I'm thinking about installing a hidden kill switch, and was curious if it would be possible to have the bike 'off' unless a momentary switch was used while kicking it over. Or would it just have to be an on/off type affair? Share this post Link to post Share on other sites
tjamscad My Ride Posted March 25, 2010 I don't think it would work like that, i beleive it would have to be on or off, Share this post Link to post Share on other sites
ruddell07 Posted March 25, 2010 Before you spend all that money, make sure the VIN# doesn't pop at the DMV. Here in Oregon, certain VIN#'s come up on their computers as Off Road Only and no matter what you do to the bike, you can't get a plate because they say it's an emissions issue. All Japanese bikes are in their computer system, but apparently KTM's are not so you can still plate them here. Hopefully you won't have any problems! Share this post Link to post Share on other sites
ruddell07 Posted March 25, 2010 One more thing, I think all street legal bikes are supposed to have a metal gas tank....? Share this post Link to post Share on other sites
nismofun Posted March 25, 2010 according to Section 7 of the Title Manual It just has to meet safety requirements. Titling Requirements for Dirt Bikes If a vehicle does not meet the definition of an all-terrain vehicle, a motorcycle, motortricycle, or a motorized bicycle, it is considered a “Dirt Bike” and must be titled. A 1982 Missouri Supreme Court decision ruled that for the purposes of collecting sales tax, a dirt bike is a motor vehicle. Therefore, it is subject to the tax provided by Section 144.070, RSMo. However, a dirt bike may not be registered for highway use, unless it is modified to meet all safety requirements and pass a safety inspection. For additional information on titling requirements for dirt bikes, please call (573) 751-4509. 🤣👍 That's the 08-08 revision on page 7-6. Good looking out though. And it's a good thing since I already spent the money. Share this post Link to post Share on other sites
tjamscad My Ride Posted March 26, 2010 how is the upgrade going, what parts have you put on already? Share this post Link to post Share on other sites
nismofun Posted March 26, 2010 (edited) Just got the bulk of it today, the only things I'm missing are the computer and headlight. Tomorrow or this weekend I'll start wiring it all in. I tested it tonight and all the connections work. The instructions are...interesting, but should be manageable. Will post when I get it all hooked up and plated. Ordered tires (k760s) and spoons to change 'em. Still $30 less than local shop. That'll pay for DIY sliders. And waiting on TTstore to ship. Hopefully it doesn't take long to get here. Edited March 26, 2010 by nismofun Share this post Link to post Share on other sites
nismofun Posted March 27, 2010 Installed most of the EZ wiring kit today. Pretty simple other than finding a spot for all the stuff behind the headlight. I had one problem, which was my fault. I over tightened the banjo bolt on the rear brake and snapped the head off. Forrest took care of me and got my replacement order out the door today. Can't beat that service. He might not be the cheapest, but he takes care of his customers. I did notice that the rear bolt with the leads on it interferes with the rear master cylinder, so I ordered the banjo low profile replacement. Hopefully that fixes the issue. If not, I'll just zip tie it on some how. I didn't get around to the edge 2 or rear blinkers today as I forgot my drill, and didn't have access to one where my bike is. Should get that done this weekend. The horn is...more like a high pitched ring than a honk since it's electric. I might end up replacing that just for personal taste. I rarely use the horn though so we'll see. TT order shipped today and should be here by Wed, and then I just have to wire up the headlight and comp, install the tires that should be here next week as well, and get an inspection. Then come the security stuff so I can actually ride on the streets. Share this post Link to post Share on other sites
tjamscad My Ride Posted April 3, 2010 well hows it going with the conversion? Share this post Link to post Share on other sites
