250 SXF Jetting
All stock, 2006 250 SXF, sea level, 80 degrees avg. temp. I just went through servicing this bike for a friend. All jets and settings are stock as the manual specifies for a baseline. However, bike starts and idles but will die upon opening the throttle. Any opinions to where I should go with the jetting on this? Thanks.
i will try it one of this weeks , and also the blue neelde (is the same thiknes as oem. ) we have a h.c. piston and special int. cam and with the oem neelde clip 3 and a main 172 its go like grazy ,even in the heavy dutch sand tracks . i have a good test rider so we see.
Definitely use the blue needle. The red one is leaner. The diam. may be the same (on the straight part) as OEM but it definitely isn´t that in the tapered part.
You need to play around with needle pos. to make it run really well. Especially if you have a modified mill...
