RTV high temp silicone as head gasket ??
No that defiantly wont work the silicone cant hold the compression or seal it changes compression ratio as well it well cause more trouble then good
thanks man.... sry i posted too fast ...i did some searching and found its not good idea cuz of compressing and getting inside the cylinder , etc. And also doesn't give correct clearance that the gasket would.
Thanks again 👍
