re-useable oil filters
I just use carb-choke cleaner and spray it from the inside out. You dont want to spray it on the outside of the filter due to debris getting in to the filter.
After you spray it from the inside out take it and blow it out with a air compressor from the inside out. then take it to the sink and use dawn and a toof brush and sud it up good and brush it on the out side and the rinse it real good.
Take some more carb spray and again spray it from the inside out and then use a air compressor again to dry it. Then you are done.
This is how i do it and it works fine.
