Correct carb hose routing 07 650L
Hi all
I have been reading as many threads as possible and still not sure.
07 XR 650L. PO installed K&N filter Cobra exhaust and some form of smog removal kit, a partially complete Daves mod, Etc.. Problem is there where many things left undone. Hose wise Im not sure where the vacuum lines on the carb go, The breather hoses comply with other posts Ive read. I have completed Daves mods 55/158 run better I removed a 160 but I might put it back. I need specific info for the desmogged XRL.
Thanks Crash
It would help if you posted some pictures of the items in question. There are only a couple hoses on there - not too hard to figure out. There is a Y fitting, the top connections go to the carb and vent up top and the bottom is just a drain.
