kxf450lc Posted March 24, 2010 My 2006 kx 450 has a 13 tooth front sprocket and 50 tooth rear, I am buying new chain and sprockets and wondering if anyone has swapped to a 48 or 49 rear, seeing the bike is a four speed i was wanting to see if there was a noticable difference in speed with these. I ride on back roads 50% of the time and ride tracks just for fun 50% of the time. I do like how it is now but why not make it better will I'm at it. Thanks Share this post Link to post Share on other sites
ridintolive Posted March 24, 2010 When I rode my 06 kawi I went to a 51t. I found the bottom end to be not there enough and I never needed to be going full speed in 4th other than on roads. I wanted more bottom end in the trees and tracks since I will never hit a jump pinned in 4th on it, way to fast and I haven't the skill to fly that far since you can clear a 70' double in 3rd gear just rolling on the throttle. cheers Share this post Link to post Share on other sites
kawiracer70 Posted March 24, 2010 I am running a stock front and a 49 rear. I just camd and installed a high compression piston. The bike is so much more powerfull I am hitting the rev limiter in 4th gear on mx tracks. I am changing back to a 48 to see if i can get a little more speed, and may have to go to a 47. Share this post Link to post Share on other sites
kxf450lc Posted March 24, 2010 Thanks for the info guys, I think the bike has good bottom end power now, well for just cruising around and riding tracks for fun. I might try a smaller sprocket. Kawiracer70 keep me posted if you swap it out again. Share this post Link to post Share on other sites
