oil amount correct
I was wondering if the stock oil amount for the 150r is correct.
I know with my 450r people recommend running about 600-700cc when it calls for 580cc on the transmission side. I guess the kick starter idler gear squeals from being under oiled.
I also run a hair more on engine side as well on the 450. it calls for 690cc i put 725c in it.
Should i be adding a little bit of extra oil to the 150r?
It cant hurt anything right?
I know the amount it calls for, which lands it between the marks. i am wondering if it needs to be a little higher than the factory recommended amount.
old-tri tank should be there thursday maybe today.
Should i be adding a little bit of extra oil ?
You were right to seek advice before putting in extra oil.
In many cases, adding too much oil CAN be counterproductive. Best to not try and second-guess the engineers.
In my experience w/ this bike(230 hrs.) there is no reason to run the oil higher than called for. However I may have overfilled the trans by an ounce or 2 , Ive had no Ill effects from that.
New tank:banana:­čĹŹ
├Ś
├Ś
