2003 DRZ400E Fuel Screw Question?
Ok, I'm taking my first run at taking my carb apart, cleaning and rejetting (Thanks for the infor Eddie!). Removed the CE and modified the diaphram in and wired the AP. Unfortunately I hastily removed the fuel screw and can't remember for sure the order of the spring, washer and o ring. Does the o ring go onto the screw first followed by the washer and then spring, or does the spring go on first followed by the washer and then the o ring???????????? Arrg! The clymer manual does not show the order on the schematic.
Second, what exactly are we talking about when you guys are saying to remove the snorkel.....as it pertains to the DRZ ­čĹŹ
Thanks in advance guys!
If I am seeing this right put the spring on the screw first then the washer and then the o-ring. Check out this picture.http://shop.thumpertalk.com/oem.asp?partcategory=89780&manufacturer=5&category=3&year=2003&model=2037 Someone will be along soon that knows for sure. I haven't played with one of those great carbs...yet.
The snorkel is #11 here.http://shop.thumpertalk.com/oem.asp?category=3&manufacturer=5&year=2003&model=2037
├Ś
├Ś
