LittleSeanX Posted March 24, 2010 When I floor it in 5th gear it misfires. I replaced the oil, spark plug, chain, and sprockets when I got it. Any help? Share this post Link to post Share on other sites
4strokeridertt My Rides (3) Posted March 24, 2010 Check the wiring. Look for a frayed wire or dirty connections. Be sure and clean the ground wire to the frame. Share this post Link to post Share on other sites
Racer Posted March 25, 2010 When I floor it in 5th gear it misfires. I replaced the oil, spark plug, chain, and sprockets when I got it. Any help? As I always say, start by giving it a tune-up. 1) Check the valve clearance and adjust to spec 2) Clean air filter 3) Pull the carb and give it a good cleaning, it must be spotless. Make sure you can clearly see through both the pilot and the main jet when held up to a light source. Be very meticulous. Share this post Link to post Share on other sites
LittleSeanX Posted March 25, 2010 any videos on how to check the valves and clean the carb? i cleaned the air filter already. Share this post Link to post Share on other sites
