How to replace a air scoop on a VxPro3 ??
One of the two air scoop is broken. Get one from a friend, but i don't see how to replace it...Under the scoop there's a screw, but how to reach it to remove the broken one and same to install new ?????
No, don't pry it and it's not glued on.. There is a little black lever sticking out the back used to open and close it. You need to put this a certain direction (I think toward the outside of the helmet) and there is a red lever also attached. While the black lever is towards the outside you swing the small red lever towards the center and then swing the entire contraption (both levers) to the center. While the black lever is in the center you pull it downwards and the scoop will pop off with a little tug.
