motocrazy450 Posted March 24, 2010 ive heard good and bad things about presure washing dirtbikes. What do you guys think? I use an electric presure washer on my 450X after every ride. Share this post Link to post Share on other sites
hadameo Posted March 24, 2010 I have heard the same,i pressure wash mine all the time but i plug my pipe,air box vents and i try not to hit my cyclinder,and electrical wires with the full pressure of water.If your bike has more mud then bike park it on your lawn(if you own one) and put a sprinkler underneath and water both! Share this post Link to post Share on other sites
77rednecktruck Posted March 24, 2010 I have heard it can blow grease out of bearings and such but there are people who never have a problem. I wash my bike to get huge chunks of dirt off and when I can't tell what color it is anymore so I really am not the best person to answer this. 👍 Share this post Link to post Share on other sites
Mike38 Posted March 24, 2010 A lot of people disagree with using a pressure washer on a motorcycle. I have always done it because I’m lazy. As long as the exhaust is capped, and you take care not to spray close and direct onto the wheel bearings, suspension bearings and electronics, I haven’t had a problem. Share this post Link to post Share on other sites
MidWest X Posted March 24, 2010 Avoid forcing water into the pivot points. I used one the entire season last year. After a winter teardown, I found no issues with my bike from water. Usually I will wet the whole bike down really good. Wait for 15 to 30 minutes for the mud to soften, and when I come back the dirt usually rinses right off. Share this post Link to post Share on other sites
MrBlahh Posted March 24, 2010 it forces water/dirt into bearings, you need to be careful around them, swingarm, linkage, axles Share this post Link to post Share on other sites
KJ790 Posted March 24, 2010 Like anything, pressure washing can be great, or it can be very damaging. A pressure washer is a tool, and like any tool it must be used correctly or it can cause damage. Don't blast at any areas where there are seals or bearings, don't blast in your airbox (a cover or some tape over the vents helps here), don't blast in your exhaust (an exhaust plug helps here), and if you want your bike to look good, don't blast your graphics off. As long as you are careful there is no problem washing your bike with a pressure washer, especially if it is one without a lot of pressure. Share this post Link to post Share on other sites
rolandk Posted March 24, 2010 Be careful around graphics and stickers too, they will fly right off. Share this post Link to post Share on other sites
sro2004 Posted March 24, 2010 I would definately use a pressure washer if I was riding multiple times per week. Unfortunately, I hardly ever get to ride twice in one week. It's either Saturday or Sunday for me. I'm always too spent right after riding to wash, so I garage it and come back to it Monday night. I'll warm up the bike, then pull the air filter (and put on a cover), plug the exhaust, cover the controls then rinse and hand wash. Usually takes me an hour. Then, one night later that week...I'll sneak out to the garage and spend an hour detailing. Heh...pretty stupid, but I don't get NEAR enough bike time, so spending time washing her and making her pretty helps a bit. Share this post Link to post Share on other sites
sro2004 Posted March 24, 2010 This is her...at 20 hours: Share this post Link to post Share on other sites
CodeMonkee Posted March 24, 2010 I don't need it. The pressure from a regular hose is plenty to wash off my bike. Share this post Link to post Share on other sites
Pedroski Posted March 24, 2010 I never use a pressure washer.....and also I have never had wheel or headstock or swingarm bearings fail. Prefer lots of water at low pressure (hose, bucket etc) to little water at high pressure. Share this post Link to post Share on other sites
justin23 Posted March 24, 2010 Just like everyone else has mentioned, if you have to use a prsser washer, be careful around bearings, exhaust, electrical, and airbox. the main thing is to not get water where its not support to be. I only use pressure wash when I dont have time to hand wash it with a garden hose. Share this post Link to post Share on other sites
detox Posted March 24, 2010 The way I see it, the areas a pressure washer works well are also were you don't want to use it. The chain, all pivots, seals, gaskets, bearings. All the easy stuff to wash by hand can handle the pressure. And if you use harsh soaps like those at a car wash, even more damage. Share this post Link to post Share on other sites
intensem1rider Posted March 24, 2010 With the type of soil around here, there is no way in the world I could wash my bike without a pressure washer. I wash it after every ride, and re-grease the bearings monthly. If your too lazy to grease your bearings before it's too late, it's your own fault. Share this post Link to post Share on other sites
MrBlahh Posted March 24, 2010 With the type of soil around here, there is no way in the world I could wash my bike without a pressure washer. I wash it after every ride, and re-grease the bearings monthly. If your too lazy to grease your bearings before it's too late, it's your own fault. how do you grease a sealed bearing? Share this post Link to post Share on other sites
markgoodall Posted March 24, 2010 My HondaGX+CatPump pressure washer is too powerful for most things, especially my bikes. I've been thinking about getting a less powerful electric one, but I find that the water pressure out of the hose is powerfull enough to clean a bike rather easily. Share this post Link to post Share on other sites
intensem1rider Posted March 24, 2010 how do you grease a sealed bearing? Take a pick and remove the seal, clean out the bearing with contact cleaner, then re-pack with grease and re-install the nylon or rubber/metal seal. Share this post Link to post Share on other sites
f4stunter Posted March 24, 2010 how do you grease a sealed bearing? If your referring to rollerbearings the seals are usually plastic and easily removed with a small screwdriver and then pressed back in. Share this post Link to post Share on other sites
