cleaner to clean my chain?
i have a stock chain on a crf450r, i have brake and carb cleaner. brake cleaner seems to do wonders, can i clean my chain with it? my chain is DIRTY and there is some gunk on there.
i know you can use kerosene or gas but i really don't feel like heading out to the store AGAIN and spending more money
thanks
No Gas, brake cleaner or carb cleaner. Really bad idea. They will wreck the o-rings and dissolve the grease in the pin/bushing area.
Use citrus based degreaser or kerosene.
Unless you have a standard chain, then clean it with whatever you have around the shop.
What about this? http://www.motosport.com/motorcycle/product/CHAIN-CLEANING-BRUSH/?catalogId=103036
ANyone have any experience with this chain cleaning brush?
just pick up a new toilet brush and dedicate it to cleaning the chain. keep the extra $7 for beer money. the toilet brush works very well. i've had my current one for 2 years and still scrubbing.
so does anyone know if a stock crf450r has an x-ring or o-ring. i'm slowly learning about this bike.
They are both O ring chains, there are a few ways of looking at the benefits of the two. The x ring lubes itself but its heavier and causes more drag (IE powerloss). The O ring chain requires you to clean and lubricate frequently.
IMO a nylon brissle brush and kerosene cleans the chains the best and a lubricant that doesnt attract dirt and fling off all over your swingarm and sprocket works the best.
CRF450R, not CRF450X, correct? Don't know about the "X", but the "R"s come with non-o/x-ring chain.
I pressure wash the bike, then srcrub the chain with a wire brush, then pressure was the chain again. Be sure to lube immediately afterwards or it turns into a rusty mess!
And those grunge brushes are a good idea, but mine broke and I never replaced it since a regular wire brush works a little better I think.
Edit:
I'm referring to non-o-ring chains here. I wouldn't metal wire brush a ringed chain.
I agree wd40 is a lubricant , for a wrist watch, but much to light for a rk520 o-ring chain. It IS one of the best cleaners made for removing gunk etc and a good lube for very light moving parts that are not exposed to the weather.
