Missing air jet
this is a 39mm fcr bought s/h believed to be from a crf 250 it has no jet where the main air jet should be is this normal for the carb as there dosent seem to be any threads to fit a jet ?? or if you have the same carb what size jet should be in there ??
tech
starter jet #68
pilot #42
main #172
paj air #100
leak #70
main air unknown as missing
needle NCY 0 3d clip from top
engine side O/D 47mm
engine side I/D 39mm
intake side O/D 56mm
intake side I/D 41mm
id FCR 01BBSG27 believed from crf 250 2005 model
Ah thats why it has no thread then , do you know what size the orifice would equate to Eddie, Im currently running a #150 main and the carb originally had a #172 so reckon there might be a bit of a difference in requirement
