Mid-float on Kyb Forks!
i am a little confused about the float on the 48mm kyb forks
on the 09 crf i have measured 0,35mm
the 07 yzf 450 has the same mid valving and 0,2 float?
20,11 3x
18,11
16,11
14,11
11,30 2x
17,30 2x
i think the sleeves are the same (5,25mm!) on all Kyb Forks
different mid-valve -pistons?
5.3mm slide collar is typical in TC KYB forks. Some models use 8-0.15 shims under the collar which increase the float. CRF -09 and YZ -07 don't have those shims std and both models have 5.3 collar, both have same valve stopper also. Pistons have same part numbers. So what we have left?
Did you measure it out the same way?
Thanks for the help.
i have not measured the yzf.
the info it´s from TT.
here is std, this is the 450 but i beleive its the same.
Stock base compression
32.12 (17)
30.12
28.12
26.12
24.12
22.12
20.12
18.12
16.1
14.25
14.25
Mid valve Stock reb
10.25
12.12
14.12
16.12
18.12
13.12
20.12
20.12
20.12
20.12
Mid valve Stock compression
20.12
20.12
20.12
18.12
16.12
14.12
11.3
11.3
17.3
17.3
float 0.2mm
i am not sure about this, mayby it´s incorrect??
has someone the correct stock yzf 450/07 stacks ??
