Just replaced timing chain after alot of hours
Well I decided to check my valves one intake was tight so I removed the cam to shim it and dropped a shim down timing chain hole M.F@@!%%% :bonk:I know better than that but was trying to hurry so I decided to change the timing chain too while I was in there and found this it looks like chain hit it1_CRF450R.015_1_.jpg
Its the oil strainer mount under the crank Im looking for the part #
please help I need to RIDE BEEN TWO WEEKS or bend it back is it a 90 degree bend ?
Part number 11206-MEB-670
its a cam chain guide plate, its supposed to have a bend in it like that. but not sure the degree of the bend to see if yurs is over bent.
That plate holds the cam chain close to the gear on the crankshaft. It is there to prevent the chain from falling away from the gear whenever the chain is loose. IE: changing the head , cam , chain tensioner.
I had accidently bent my bracket like that in your picture. I took it off and bent it back up, closer to the gear. And all is well.
