Can you double check cam chain timing for me? PICS
Just installed a new cam chain, old one was stretching. I turned the engine over forward by hand a few revolutions before taking the pictures. 10 and 2, and 15 pins right? Also the MCCT is just turned to take out slack. Let me know what you think.
Edit: having trouble with the pics.
Looks good to me. TDC, compression stroke, both cam lobes off the buckets and pointed out - count 15 pins between the vertical 2 and 3 arrows?
Once its all together just crank it over by hand carefully and make sure there are not sudden valve to piston stoppages in there 👍
