2004 crf250r won't start, Valves in spec, timing is dead on
Assuming the timing is correct check your valve clearances again.
Choke on. 5 Twists. Hand off the throttle. Kick slowly until you hear the click. Then kick it hard until it starts.
Can you push or tow start it?
We just shimmed the valves it's still around 40 degrees here, we shimmed the valves into spec and tried 3 different spots for timing, it still will not start. Anyone have any ideas?
Are you sure the cam lobes are facing the rear of the bike?
