Freshly restored 434- photos
So I bought a spare DRZ engine to fix up and install for backup purposes while the original engine is out for its 470cc upgrade. Keep in mind the restored engine was from an E model and initially resembled a small hill of dirt and oil and flaked off paint than an engine when it arrived.... I cleaned up and resprayed the whole thing and put in the JE piston and cylinder works upgrade. Also had to have a dodgy cam journal welded up and remachined by a friend - but the engine runs mint now. Did all the fixes and checks while in the rebuild process so this should be a reliable thumper. It sure pulls hard.
But now.
Here incidentally is the original engine receiving its +5mm Hotrods stroker crank...
Out with the old, in with the new
This, incidentally, is the 'mototune' -'impossible' 94mm JE piston I broke in in this engine. See how shiny and well sealed it is....
http://www.mototuneusa.com/break_in_secrets.htm
Edited by Svery
Yeah, I'm in the process of making a MCCT - the ACCT in there has been ok with the 434cc engine though I don't intend to use it in the stroker.
Copper spray a gasket? I'm only using the one layer base gasket, I figured the copper spray would at worst do nothing, at best seal a little better even though its not really necessary due to the low pressures at the base. And copper looks purty 👍
ok ~ many years ago i used a sealant on my XR 600 base gasket , after 250 klm the gasket pushed out . it was'nt copper coat though .
i had to do it all over again , before i pulled it apart i could see the gasket working its way out .
all the best with the stroker motor .. well worth the cost and effort 👍
