Idle adjustment
The idle adjustment screw is located on the left side of the engine (when sitting on it). Look below the choke pull knob and you will see a phillips head screw with a nut around (to secure the screw from rotating once you get the idle where you want it). Been awhile since I adjusted mine so can't remember which way to turn it to make it idle higher but just go ahead and loosen the locknut and get your bike warmed up with a phillips head screwdriver in hand and start turning in or out until it is where you like it. Then lock it down with the locknut.
+1:thumbsup:
